Article ID : 00343599 / Last Modified : 18/02/2025Print
    Notice of free repair program for some CFexpress Type A memory cards of CEA-G Series
    Thank you for your interest in Sony products.
    Sony has identified an issue with a batch of CEA-G series memory cards. These memory cards may not be recognised or may fail to save images in low-temperature conditions, around -10 degrees Celsius.
    Although it is exceedingly rare that your card will experience this issue, you may not be able to use or recover the data from your memory card once it occurs
    We are offering a free repair program from June 26, 2024 until June 29, 2029 for the affected memory cards to address this.
    If your memory card is part of this batch, please get in touch with a Sony Alpha Authorized Service Center within the specified repair period to receive a free repair.
    We apologise for any inconvenience this may cause and appreciate your understanding and cooperation.
    Which Sony Alpha Authorised Service Center do I contact?
    It's important to note that not every Service Center is specialised in Sony Alpha technology.
    Please use the correct filter when searching for an Authorised Service Center:
    1. Go to our Authorised Service Center locator tool.
    2. Underneath the search bar, select your product category.
    3. Filter on "camera & camcorders" or 'digital cameras' (country dependant).
    Back up your memory card if possible
    Before sending the memory card for repair, please back up the contents and erase them from the memory card.
    All content and data on the memory card will be deleted during the repair process.
    Affected memory card types and lot numbers
    Where can I find the 8 or 9 digit lot number of my memory card?
    You can find the memory card lot number at the bottom on the back of the card.
    CEA-G80T
    • Memory cards of this type with 8-digit lot numbers from 22030050 to 23050157,
      except for 22030077, 22030094, 22040022, 22050028, 22050067, 22070075, 22110010, 22110015, 22110029, 22110037, 22110103
    • Memory cards of this type with 9-digit lot numbers from 220300500 to 230501570
    CEA-G160T
    • Memory cards of this type with 8-digit lot numbers from 22030127 to 24029999,
      • except for 22040025, 22040068, 22050029, 22050068, 22070076
    • Memory cards of this type with 9-digit lot numbers from 220301270 to 240299990
    CEA-G320T
    • Memory cards of this type with 8-digit lot numbers from:
      • 22090001 to 24029999
      • 22040001 to 22080110 (Added on January 21, 2025)
    • Memory cards of this type with 9-digit lot numbers from:
      • 220900010 to 240299990
      • 220400010 to 220801100 (Added on January 21, 2025)
    CEA-G640T
      • 23010001 to 24029999
      • 22080001 to 22100136 (Added on January 21, 2025)
      • 230100010 to 240299990
      • 220800010 to 221001360 (Added on January 21, 2025)
