Article ID : 00248363 / Last Modified : 20/08/2021
Wall mounting: Compatible wall-mount brackets and screw hole distance measurements for BRAVIA TVs (2020 models)
    Please check the compatible Wall-mount Bracket in the Compatibility Chart included in this article.
    WARNING: There is a risk of personal injury.
    • For product protection and safety reasons, Sony recommends having Sony dealers or licensed contractors mount your TV on the wall.
    • For safety reasons and to ensure a correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
    Table of contents
    1. How to read the measurements used in the Compatibility Chart
    2. Compatibility Chart
    3. Is my wall strong enough to mount a TV?
    4. What screws should I use to mount my TV?
    Screw hole distance measurements
    The screw hole distance measurement in the Compatibility Chart corresponds to the Width x Height measurement and is expressed in mm (e.g. 300 x 300). The diagram below illustrates the rear side of a BRAVIA TV.
    The back side of a BRAVIA TV where A = width, B = height, C = screw holes location.
    1. A = Width (W)
    2. B = Height (H)
    3. C = Screw holes location
    Notes:
    • In some BRAVIA TV models, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
    • Sony cannot guarantee the use of a third-party wall mount bracket to mount the BRAVIA TV.
    • For more detailed information and precautions about wall mounting, see the manuals of your TV and wall mount bracket.
    AC Power adapter size
    The AC Power adapter size corresponds to the Width x Height x Depth measurement expressed in mm (e.g. 191 x 80 x 39). Please note that an AC Power adapter only comes with certain models. The diagram below illustrates how the compatible AC Power adapter size (W x H x D) is measured in the Compatibility Chart.
    Ac Power adapter size
    1. A = Width (W)
    2. B = Height (H)
    3. C = Depth (D)
    Compatibility chart
    2020 models
    Series NameModel NameInchesCompatible Wall-Mount BracketScrew hole size
    (W x H) mm
    Length of power cord (mains lead)Weight of TV without Stand
    A9 SeriesKD-48A948SU-WL450 *1
    SU-WL850
    300 x 3001.5 m13.9 kg
    A89 SeriesKD-65A8965SU-WL450 *1
    SU-WL850
    300 x 3002 m21.8 kg
    KD-55A8955SU-WL450 *1
    SU-WL850
    300 x 3001.5 m16.8 kg
    A87 SeriesKD-65A8765SU-WL450 *1
    SU-WL850
    300 x 3002 m21.8 kg
    KD-55A8755SU-WL450 *1
    SU-WL850
    A85 SeriesKD-65A8565SU-WL450 *1
    SU-WL850
    300 x 3002 m21.8 kg
    KD-55A8555SU-WL450 *1
    SU-WL850
    A8 SeriesKD-65A865SU-WL450 *1
    SU-WL850
    300 x 3002 m21.8 kg
    KD-55A855SU-WL450 *1
    SU-WL850
    ZH8 SeriesKD-85ZH885SU-WL450 *1400 x 4002 m65.6 kg
    KD-75ZH875SU-WL450 *1400 x 4002 m47.9 kg
    XH9505 SeriesKD-85XH950585SU-WL450 *1400 x 4002 m46.0 kg
    KD-75XH950575SU-WL450 *1
    SU-WL850
    400 x 3001.5 m33.1 kg
    KD-65XH950565SU-WL450 *1
    SU-WL850
    300 x 3001.5 m22.3 kg
    KD-55XH950555SU-WL450 *1
    SU-WL850
    KD-49XH950549SU-WL450 *1200 x 2001.5 m13.3 kg
    XH9299 SeriesKD-75XH929975SU-WL450 *1
    SU-WL850
    300 x 3001.5 m32.9 kg
    KD-65XH929965SU-WL450 *1
    SU-WL850
    300 x 3001.5 m22.2 kg
    KD-55XH929955SU-WL450 *1
    SU-WL850
    300 x 3001.5 m16.5 kg
    XH9296 SeriesKD-75XH929675SU-WL450 *1
    SU-WL850
    KD-65XH929665SU-WL450 *1
    SU-WL850
    KD-55XH929655SU-WL450 *1
    SU-WL850
    XH9288 SeriesKD-75XH928875SU-WL450 *1
    SU-WL850
    KD-65XH928865SU-WL450 *1
    SU-WL850
    KD-55XH928855SU-WL450 *1
    SU-WL850
    XH9196 SeriesKD-49XH919649SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    Length of AC Power Cord
    0.5 m
    (191 x 80 x 39) or (170 x 85 x 40)
    13.2 kg
    KD-43XH919643SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XH9096 SeriesKD-85XH909685SU-WL450 *1400 x 4001.5 m45.8 kg
    KD-75XH909675SU-WL450 *1
    SU-WL850
    KD-65XH909665SU-WL450 *1
    SU-WL850
    KD-55XH909655SU-WL450 *1
    SU-WL850
    XH9077 SeriesKD-65XH907765SU-WL450 *1
    SU-WL850
    KD-55XH907755SU-WL450 *1
    SU-WL850
    XH9005 SeriesKD-75XH900575SU-WL450 *1
    SU-WL850
    KD-65XH900565SU-WL450 *1
    SU-WL850
    KD-55XH900555SU-WL450 *1
    SU-WL850
    XH8599 SeriesKD-49XH859949SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    KD-43XH859943SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XH8596 SeriesKD-49XH859649SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m (Russia: 1.5 m)
    13.2 kg
    KD-43XH859643SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XH8588 SeriesKD-49XH858849SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    KD-43XH858843SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XH8577 SeriesKD-49XH857749SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    XH8505 SeriesKD-49XH850549SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    KD-43XH850543SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XH8196 SeriesKD-65XH819665SU-WL450 *1
    SU-WL850
    300 x 3001.5 m21.7 kg
    KD-55XH819655SU-WL450 *1
    SU-WL850
    300 x 3001.5 m16.0 kg
    KD-49XH819649SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (158 x 70.5 x 35) or (155 x 67 x 36.5)
    11.6 kg
    KD-43XH819643SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.4 kg
    XH8096 SeriesKD-85XH809685SU-WL450 *1400 x 4001.5 m44.1 kg
    KD-75XH809675SU-WL450 *1
    SU-WL850
    300 x 3001.5 m31.8 kg
    KD-65XH809665SU-WL450 *1
    SU-WL850
    KD-55XH809655SU-WL450 *1
    SU-WL850
    KD-49XH809649SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    11.6 kg
    KD-43XH809643SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    9.4 kg
    XH8077 SeriesKD-65XH807765SU-WL450 *1
    SU-WL850
    KD-55XH807755SU-WL450 *1
    SU-WL850
    KD-49XH807749SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11.6 kg
    KD-43XH807743SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.4 kg
    XH8005 SeriesKD-55XH800555SU-WL450 *1
    SU-WL850
    KD-49XH800549SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    1.5 m
    11.6 kg
    KD-43XH800543SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    1.5 m
    9.4 kg
    X7056 SeriesKD-65X705665SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55X705655SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49X705649SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (155 x 67 x 36.5) or (158 x 70.5 x 35)
    11.9 kg
    KD-43X705643SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32) or (157 x 65 x 32)
    9.7 kg
    X7055 SeriesKD-65X705565SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55X705555SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49X705549SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11.9 kg
    KD-43X705543SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.7 kg
    X7053 SeriesKD-65X705365SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55X705355SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49X705349SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11.9 kg
    KD-43X705343SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.7 kg
    X7052 SeriesKD-65X705265SU-WL450 *1300 x 3001.5 m20.5 kg
    KD-55X705255SU-WL450 *1200 x 2001.5 m15.4 kg
    KD-49X705249SU-WL450 *1200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11.9 kg
    KD-43X705243SU-WL450 *1100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.7 kg
    *1 Use of the rear terminal will be limited depending on the wall mounting style. Refer to the Installation instructions (Wall-Mount Bracket) for the TV.
    The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page. If the strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult Sony dealers or licensed contractors.
    When attaching the Wall-Mount Bracket to the TV, use the screws supplied with the Wall-Mount Bracket. The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket). If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV. For details about the screws you should use, refer to the Installation instructions (Wall-Mount Bracket) for the TV or Operating Instructions or Reference Guide for the TV.
