Article ID : 00240478 / Last Modified : 19/01/2026Print
Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2015 models)
    Please see the following chart and check the compatible Wall-mount Bracket for your TV.
    WARNING: There is a risk of personal injury.
    • For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
    • For safety reasons and to ensure correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
    To see the compatibility chart
    Compatibility chart
    About the Strength of Walls
    About Screws
    • The screw hole distance measurements: Width x Height expressed in mm
      The diagram shows the rear side of the BRAVIA TV.
      back side of the BRAVIA TV
      1. W (width)
      2. H (height)
      3. screw holes
      NOTE:
      • In some models of BRAVIA TV, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
      • Sony cannot guarantee the use of a third-party wall mount bracket to mount the BRAVIA TV.
      • For more detailed information and precautions about wall mounting, see the manuals of your TV and wall mount bracket.
    • AC Power adapter size: Width x Height x Depth expressed in mm
      An AC power adapter comes with some models. The diagram shows the AC Power adapter size compatibilities (W x H x D) in the Compatibility Chart.
      Ac Power adapter size
      1. W (width)
      2. H (height)
      3. D (depth)
    Compatibility chart
    2015 models
    Series Name
    Model Name
    Inches
    Compatible Wall-Mount Bracket
    Screw hole size
    (W x H) mm
    Screws (Supplied with Wall-Mount Bracket)
    Length of power cord (mains lead)
    Weight of TV without Stand
    X93xxC_X94xxC Series
    KD-75X9405C
    75
    400 x 300
    1.5 m
    56.0 kg
    KD-65X9305C
    65
    SU-WL450 *1
    400 x 300
    +PSW 6x20, +PSW 6x50
    1.5 m
    47.3 kg
    KD-55X9305C
    55
    300 x 300
    1.5 m
    37.3 kg
    X90xxC_X91xxC Series
    KD-75X9105C
    75
    Wall-Mount Bracket accessories supplied with your TV
    400 x 300
    Easy Wall Hanging
    1.5 m
    33.7 kg
    KD-65X9005C
    65
    300 x 300
    Easy Wall Hanging
    1.5 m
    23.2 kg
    KD-55X9005C
    55
    300 x 300
    Easy Wall Hanging
    1.5 m
    18.4 kg
    X85xxC Series
    KD-75X8505C
    KD-75X8501C
    75
    400 x 300
    1.5 m
    34.8 kg
    KD-65X8509C
    KD-65X8508C
    KD-65X8507C
    KD-65X8505C
    KD-65X8501C
    65
    SU-WL450 *2
    400 x 300
    1.5 m
    24.1 kg
    KD-55X8509C
    KD-55X8508C
    KD-55X8507C
    KD-55X8505C
    KD-55X8501C
    55
    300 x 300
    1.5 m
    19.9 kg
    X83xxC Series
    KD-49X8309C
    KD-49X8308C
    KD-49X8307C
    KD-49X8305C
    KD-49X8301C
    49
    SU-WL450 *2
    300 x 300
    1.5 m
    14.4 kg
    KD-43X8309C
    KD-43X8308C
    KD-43X8307C
    KD-43X8305C
    KD-43X8301C
    43
    200 x 300
    1.5 m
    11.8 kg
    X80xxC Series
    KD-55X8005C
    55
    SU-WL450 *2
    300 x 300
    1.5 m
    17.3 kg
    KD-49X8005C
    49
    200 x 300
    1.5 m
    13.2 kg
    S85xxC Series
    KD-65S8505C
    65
    SU-WL450 *2
    400 x 300
    1.5 m
    30.1 kg
    KD-55S8505C
    55
    300 x 300
    1.5 m
    22.9 kg
    S80xxC Series
    KD-65S8005C
    65
    SU-WL450 *2
    400 x 300
    1.5 m
    30.1 kg
    KD-55S8005C
    55
    300 x 300
    1.5 m
    22.9 kg
    *1 With Slim Mount, use of the rear terminal is limited. With Super Slim Mount, use of the side terminals is limited, while the rear terminal cannot be accessed at all.
    *2 With Standard Mount, use of the rear terminal is limited. With Slim Mount, use of the side terminals is limited, while the rear terminal cannot be accessed at all.
    The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page.
    If the strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult Sony dealers or licensed contractors.
    About Screws
    When attaching the Wall-Mount Bracket to the TV, use the screws supplied with the Wall-Mount Bracket.
    The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket).
    If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV.
