Your Android™ TV can't play films, videos, images, or audio files stored on your home network server if the file's codec is unsupported and you are connected through a proxy.
To play back files stored on your home network server, it is necessary to establish a connection between the Android TV and the server.
- Make sure that your TV supports the codec of the files you want to play. For supported codecs, check your TV Help guide.
- Make sure that your TV isn't connected to a proxy server. Depending on your TV's software version, disable the Proxy settings.
Adjust the Network settings
BRAVIA TV-side setup
- Using the supplied remote control, press the HOME button.
- Select
Settings.
- Select Network in the NETWORK & ACCESSORIES category.
- Select Home network setup.
- Select Server diagnostics.
- Select Yes.
- NOTE: The "Servers could not be found" message will be displayed if devices are not connected.
Server-side setup
- Refer to the instruction manual of your server equipment to connect it to the home network.
Disable the Proxy settings
If a proxy is set, the contents of the home network cannot be played. Follow the steps below to disable the Proxy settings
For Android™ 7.0 (Nougat) or later
- Select
Settings.
- Select Network setup.
- Select Expert.
- If you're using a wired LAN, select Proxy settings in the Wired LAN category.
- If you're using a wireless LAN, select SSID in Available networks, then select Proxy settings.
- Select NONE.
For Android 6.0 (Marshmallow) or earlier
- Select Settings.
- Select Expert.
- If you're using a wired LAN, select Wired LAN.
- If you're using a wireless LAN, select Wi-Fi and select SSID.
- Select Advanced options.
- Select Proxy settings.
- Select NONE.
NOTE: For steps to connect your server to your network, check its manual or contact the manufacturer for further assistance. Manuals are posted on our support website.
*Android, Android TV are trademarks of Google LLC.
