Article ID : 00169902 / Last Modified : 16/01/2026Print
    When connecting the PlayStation 4 Pro and the TV with the port replicator (PTR-BR100), the screen may become dark
    When you set External inputs to Enhanced format while the PlayStation 4 Pro and the TV are connected with the port replicator (PTR-BR100), this phenomenon may occur.
    Please connect the PlayStation 4 Pro and the TV directly with the HDMI cable.
    NOTE:
    • Use the HDMI cable that is bundled with PlayStation 4 Pro or the premium cable compatible with 18 Gbps.
    • An Android TV released in 2015 or later does not support the port replicator (PTR-BR100) connection.
