Article ID : 00158500 / Last Modified : 06/07/2026Print
    The screen appears to have a cloudy, white shadow or bright spots when there is no input or when viewing very dark scenes
    The LCD screen is made with high-precision technology to achieve a high level of performance and picture quality. To achieve this level of performance, the backlight setting of the TV is set to maximise the screen brightness. However, uneven brightness may be observed when the TV is viewed in a dark environment without a video input source, or with a blank screen. This condition is normal and not a malfunction of the TV.
    If you should find this affects your enjoyment, here are a few adjustments that can be made to minimise this condition.
    NOTE: Some of the steps listed below may not be available on all television models. If specific information is required to complete any of the steps, refer to the instruction manual of the television.
    • Reduce the Backlight Level in the Picture Settings Menu.
    • Turn the Light Sensor setting to On in the Setup Menu.
    • Change the Power Saving setting to Low or High in the Setup Menu.
