Article ID : 00227118 / Last Modified : 19/01/2026Print
    How can I find information about the remote control bundled with my TV?
    You can find information about your TV’s bundled remote control by going to model-specific TV information on this support site.
    Step 1: Finding your TV Remote’s model name
    The model name – a series of letters and numbers – can be found on the remote control itself. Here are a few examples of remote models:
    • RM-GD020
    • RMF-TX800P
    The model name is either on the front of the remote control or inside the battery compartment (or cover).
    If you cannot open the battery compartment or cover, refer to the article How to open the battery compartment of TV remote control.
    Example of where the model name is located on the remote.
    Step 2: Searching for the model name on the support site
    Go to the Sony Support Website, type in your remote model name into the search bar and press enter. The remote model should automatically appear together with the TV model. Then select your TV model.
    Step 3: Go to your TV’s model page
    Once you’re on the TV’s product support page, you can see the basic information about the remote in the Reference Guide / Operating Instructions or Help Guide. It shows you the buttons and the functions available.
    Also, by typing in keywords such as “remote” or “remote control” in the search box, you can find related articles.
    Notes:
    • If you encounter an issue with your remote control, such as buttons not working or voice search not working, refer to the TV remote troubleshooting page.
    • The remote control shape, availability, and function of buttons may vary depending on your region, country, or TV model.
