Article ID : 00227435 / Last Modified : 27/06/2019Print
    The Picture Mode of my Android TV automatically switches to Vivid
    If the Android TV™ automatically switches to Vivid after you changed the Picture Mode settings to Standard or Custom, check the following:
    Make sure the Auto Picture Mode is Off
    1. On the remote control, press the HOME button.
    2. Select Settings.
    3. Under the TV category, select Picture & Display.
      TV category and Picture&Display
    4. Select Picture Adjustments.
    5. Select Auto Picture Mode.
    6. Select Off.
      Auto Picture Mode
    Make sure the Picture Reset Mode is Off.
    2. Select Settings.
    3. Under the System Preferences category, select Retail mode settings.
    4. Select Picture Reset Mode.
    5. Select Off.
    Make sure DEMO mode is off.
    If the issue isn't resolved after following the troubleshooting steps above, perform a factory reset.
