Article ID : 00285198 / Last Modified : 25/05/2026Print
    The headphones do not charge (Headband/In-Ear)
    Before you start
    • If your headphones come with a USB Type-C® cable, try charging them using the supplied cable.
    • We recommend charging the headphones in a place with an appropriate ambient temperature, for example between 15 °C and 35 °C (59 °F - 95 °F) for the 1000X THE COLLEXION. Efficient charging may not be possible outside this range. For details, refer to your model's Help Guide.
    • For 1000X THE COLLEXION, WH-1000XM6: When using the headphones while charging, charging will stop at approximately 80% (if the battery level is more than 80%, charging will not start). The value is a rough estimate. The value may vary depending on the ambient environment.
    Solution
    1. Charge the headphones for five minutes, and check the status of the indicator.
      The location and color of the indicator differ depending on the model. Refer to the Help Guide for model-specific information.
      The indicator lights up.
      The headphones are in the process of charging. Wait until the headphones are fully charged.
      The indicator does not light up.
    2. Disconnect the USB cable and then reconnect it, and try charging again.
      • Make sure the USB cable is firmly connected to the headphones.
      • If you are using a USB AC adaptor, also make sure that the USB AC adaptor is firmly plugged into the AC outlet.
      The issue was caused because the USB cable was not firmly connected.
    3. Try charging using another USB AC adaptor or USB port.
      • If you have another USB AC adaptor, use it to charge the headphones.
      • If you are charging the headphones through a computer, connect them to a different USB port.
      Images examples of wearing the headphones labeled A, B respectively
      The AC adaptor or USB port may not be working. Contact the manufacturer.
      • If you are charging the headphones by connecting them to a computer, go to step 4.
      • If you are charging the headphones using a device other than a computer, go to step 5.
    4. Check the status of the computer, and try charging again.
      • Check that the computer is turned on. Turn the computer on or wake it up if it is in Standby (Sleep) or Hibernation mode.
      • Connect the headphones directly to the computer, not using a USB hub.
      • Update the OS of the computer to the latest version.
      • Restart the computer, and then reconnect the USB Type-C cable.
    5. Check if you can charge a different device with the same AC adaptor or USB port.
      The device can be charged.
      The device also cannot be charged.
    6. Reset (restart) the headphones.
      For details on how to reset the headphones, refer to your model's Help Guide.
      The issue is resolved.
      The issue may be caused by a temporary malfunction of the headphones.
      The issue is not resolved.
    7. Initialize the headphones, and then try the pairing again.
      For details on how to Initialize the headphones, refer to your model's Help Guide.
      Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
