Article ID : 00097951 / Last Modified : 09/09/2026Print
    What is the minimum viewing distance for my TV?
    Best viewing distance from the LCD TV
    The recommended viewing distance depends on your TV’s screen size and resolution.
    Quick guide:
    • 4K TVs: At least 1.5 times the screen’s vertical height
    • High Definition (HD) TVs: At least 3 times the screen’s vertical height
    • Standard Definition (SD) TVs: Approximately 6 times the screen’s vertical height
    Notes:
    These are minimum recommended distances. Adjust your seating position based on the content, room layout, viewing environment, and your personal comfort. Take regular breaks during extended viewing.
    To find your TV’s vertical screen height, check its specifications under Dimensions and Weight.
    Recommended viewing distance for 4K TVs
    For a 4K TV, sit at least 1.5 times the screen’s vertical height away. At this distance, individual pixels should no longer be visible to the naked eye.
    TV sizeApproximate minimum viewing distance
    43 inches90 cm / 2.95 ft
    49 inches1 m / 3.28 ft
    55 inches1 m / 3.28 ft
    65 inches1.2 m / 3.94 ft
    75 inches1.4 m / 4.60 ft
    85 inches1.6 m / 5.25 ft
    For a 4K TV, the minimum viewing distance is 1.5 times the screen’s vertical height.
    Recommended viewing distance for HD TVs
    For a High Definition TV, sit at least 3 times the screen’s vertical height away.
    22 inches80 cm / 2.62 ft
    26 inches1 m / 3.28 ft
    32 inches1.2 m / 3.94 ft
    40 inches1.5 m / 4.92 ft
    43 inches1.7 m / 5.57 ft
    46 inches1.7 m / 5.57 ft
    49 inches1.9 m / 6.23 ft
    50 inches1.9 m / 6.23 ft
    55 inches2.1 m / 6.89 ft
    60 inches2.3 m / 7.55 ft
    For an HD TV, the minimum viewing distance is 3 times the screen’s vertical height.
    Recommended viewing distance for SD TVs
    For a Standard Definition TV, sit approximately 6 times the screen’s vertical height away.
