Article ID : 00112912 / Last Modified : 10/09/2021Print
    How much storage space is available on my Sony Android TV?
    Your Sony Android TV will come with a predefined amount of built-in storage. The total amount of free internal space available may vary depending on the model. For model-specific information, refer to your TV's specifications. TV Specifications are posted on your TV model page on our support website. Here is an example specifications page (model KD-49XH9505).
    Check how much storage is available on your TV
    You can see how much space your apps, videos or images are currently consuming by following the steps below:
    1. Press the HOME button on the remote.
    2. Select [Settings].*
    3. Select [Storage & Reset] in the TV category.
    4. Select [Storage] or [Internal Shared Storage] to see a list of stored apps, pictures and downloads.
    5. Select [Available].
    Notes:
    • *For Android Oreo (OSV-O), the Settings icon Settings icon is located in the top right-hand corner.
    • Applications may need space for the initial download and additional space for in-app game content or other data.
    • You can transfer games and apps to portable storage devices, such as USB sticks or hard disk drives (HDDs).
    • The menu path provided here is for reference only and may vary depending on the country, TV model or firmware version.
    • Related article: The storage capacity of my Android TV is less than what's listed in the specifications.
