Article ID : 00257433 / Last Modified : 10/02/2026Print
    How to set up your TV with the Amazon Alexa app
    To connect your TV to the Amazon Alexa app, follow these steps:
    1. Go to the Home screen by pressing the HOME button on the supplied remote control.
    2. The next steps depend on your TV menu options:
    • Option 1: If TV Control with Smart Speakers app or TV Control Setup with Amazon Alexa app is displayed on the Home screen, select one of them.
    • Option 2 under Your apps, select See all — TV Control with Smart Speakers app.
    • Option 3: Select Apps — TV Control Setup with Amazon Alexa app.
      If your TV does not support the Amazon Alexa app, neither [TV Control with Smart Speakers] app nor [TV Control Setup with Amazon Alexa] app appears in the apps list.
    Select the app that applies to your situation
    Amazon and Alexa are trademarks of Amazon.com, Inc. or its affiliates.
