Article ID : 00240027 / Last Modified : 19/01/2026Print
    Smart Speaker
    • The connection examples below are illustrated using the LF-S50G. This model is available in limited countries or regions only.
    • To use your Smart Speaker as a Bluetooth speaker, you need to pair the system and TV using the BLUETOOTH function. Pairing is the process required to mutually register the information on Bluetooth devices to be connected wirelessly in advance.
    • The TV needs to be compatible with Bluetooth A2DP (Advanced Audio Distribution Profile).
    • This function is available only for Sony TVs that are compatible with Bluetooth A2DP. Check here for compatible Sony TVs.
    • Only one Bluetooth audio device can be connected to the TV at a time. It is possible to connect Bluetooth devices other than the Smart Speaker at the same time.
    • For other Bluetooth Smart Speaker devices, if the device supports A2DP, there is a possibility that it can be used. However, Sony does not guarantee the operation as a manufacturer.
    To set up a Smart Speaker with your Android TV™, you will need the following:
    • A Smart Speaker
    • An Android TV with updated software.
    • A mobile device with an Android™ or iOS™ operating system (to set up the Google Home app)
    1. Connect the AC adaptor.
    2. Connect AC adaptor
    3. Install the Google Home app on a smartphone/iPhone.
    4. Set up a Wi-Fi connection in the app. Follow the directions in the app to set up your speaker with Wi-Fi. Set the speaker to the same Wi-Fi as the smartphone/iPhone.
      *Depending on your service, you may have to create an account in advance.
    5. Setup Wi-Fi with App
    Wirelessly connecting a Sony TV using the BLUETOOTH function
    Note: You need to establish a Wi-Fi connection first in order to use the Bluetooth function of your wireless speaker. Connect it to an active network during the initial setup, then pair and connect it to a Bluetooth device.
    When using a Sony TV with the BLUETOOTH function, you can use the Smart Speaker as a Bluetooth speaker.
    To connect the Smart Speaker and TV wirelessly, you need to pair the system and TV using the BLUETOOTH function. Pairing is the process required to mutually register the information on BLUETOOTH devices to be connected wirelessly in advance
    1. Press and hold the (Bluetooth)/PAIRING button to set your speaker into Bluetooth pairing mode.
    2. Bluetooth Pairing
    3. Turn on the TV.
    4. Turn the TV Bluetooth on by going to Settings → Remote & Accesories or Bluetooth settings.
      The next steps will depend on your TV menu options:
      • A. Select Bluetooth → On.
      • B. Select Bluetooth settings → Bluetooth → On.
    5. Establish a Bluetooth pairing. From your TV Bluetooth settings, find and select your speaker's name. If a passkey* entry is prompted on the Bluetooth device, enter “0000.
      ”* A passkey may also be called “Passcode,” “PIN code,” “PIN number” or “Password.”
    6. Establish Bluetooth pairing
    7. Start playback.
    8. Playback
    For other Smart Speaker systems
    Refer to the startup guide/manual of your Smart Speaker to find out how to connect it to your TV.
    In the event of issues, such as no sound coming out even when using applicable products, refer to the following FAQ:
    Troubleshooting for the Bluetooth connection with the audio device on Android TV.
