Article ID : 00398594 / Last Modified : 20/04/2026Print
    After sorting the satellite channels in the channel list edit, the list may switch to terrestrial digital channels, or vice versa (BRAVIA 3 / 2II Series)
    IMPORTANT: This article only applies to specific products. Please check the Applicable Products of this article.
    If the satellite broadcasting and terrestrial digital broadcasting lists are swapped while sorting satellite channels in Channel list edit, please view the broadcasting wave you want to sort before continuing.
    Follow these steps to edit the satellite broadcasting.
    1. Open the liveTV app via the TV button on the remote control, or go to Home and select the TV app icon.
    2. Press the Input button and select the satellite source.
    3. Then, press the (Quick Settings) button → Settings → Channels & Inputs → Channels → Channel list edit → Select Satellite.
    4. Perform the sort operation for satellite channels.
    Similarly, if the channel list switches to satellite while sorting the terrestrial digital broadcasting in Channel list edit, please select the terrestrial digital broadcasting source when pressing the Input button in step 2.
    Note: This issue will be improved in an upcoming software update. Please install the update when it becomes available for your TV.
