undefined : 00356186 / undefined : 13/07/2025
    Sony TV Tips: Improve your TV’s Performance
    If you feel like your Sony TV’s performance isn’t quite as fast as it used to be, here are a few quick and easy things you can try that might improve its performance.
    1. Perform a Full Restart
    Normally, when you press the power button on your Sony TV remote, you’re actually just putting your TV on standby. Fully restarting your TV every now and again can help with a lot of issues, including performance. To fully restart your TV, press and hold the power button on your remote for five seconds, then press Restart when prompted. This will fully power off and back on your Sony TV.
    2. Update Your Sony TV
    Updates often bring a wide variety of improvements, including security and performance enhancements. To check if there’s an update available, navigate to:
    • Settings → System → About → Update
    If your TV is not connected to the internet and you still want to update it, check the link in the video description for a guide on updating your TV with a USB stick.
    3. Clear Cached Data
    Your TV builds up cached data over time to help apps and services run more smoothly. However, this can eventually take up space and affect performance. You can clear this cached data to free up memory by going to:
    • Settings → System → Storage → Cached Data
    4. Perform a Factory Reset
    If all else fails, a full factory reset can bring your TV back to a clean slate. Be aware that this will erase any files stored on the TV, so make sure to back up anything important before proceeding. To do a factory reset, go to:
    • Settings → System → About → Reset
    That’s all the time we have for this video. If you have more questions about your Sony TV, you can always visit the Sony Support website for more information. Thank you for watching!
