Applicable TV Models
For the CMU-BC1 as an optional accessory:
2025 Sony TVs: BRAVIA 8 II and BRAVIA 5 (except BRAVIA 3)
2024 Sony TVs: BRAVIA 9, BRAVIA 8, BRAVIA 7
2023 Sony TVs: A80L, A83L, A84L, X95L, X90L, X85L, X80L, X75WL
2022 Sony TVs: X95K, A90K, A80K, A83K, A84K, A75K, X90K, X92K, X93K, X94K, X89K, X85K, X81K, X82K, X80K, X90S, X94S (except X72K, X73K)
For the CMU-BC1M as an included accessory:
2023 Sony TVs: A95L model series
2022 Sony TVs: Z9K, A95K model series
Note: The BRAVIA Cam CMU-BC1 is an optional accessory. The BRAVIA Cam CMU-BC1M is included only with the Z9K, A95K, and A95L model series.
If you connect the external camera BRAVIA Cam to your supported BRAVIA TV, you can enjoy new features such as Video Chat, or Gesture Control to control your TV without using the remote control.
Note: The Gesture Control and camera-sensing functions are available with a software update. Downloads are posted on your model support page.
Table of Contents:
This page will explain some frequently asked questions about the BRAVIA Cam.
Click or tap the link to quickly move to the corresponding section. In the article, you can tap the questions to reveal the answers.
- Basic Information
- Camera sensing functions
- Video Chat
- LED
- Screen and picture quality
- Software update
- Others
Basic Information on BRAVIA Cam
Capabilities
What's the difference between the BRAVIA Cam and other cameras?
How many cameras can I connect simultaneously to the TV?
Preparation/initial settings
Where should the BRAVIA Cam be attached?
How do I use the camera cover switch?
Do I need to change the BRAVIA Cam settings when I connect it to the TV?
Information on BRAVIA Cam's Camera sensing functions
General specifications
- The camera sensing functions will be available after installing the latest software update.
- If your BRAVIA TV supports the camera sensing functions, Proximity Alert is displayed in the BRAVIA Cam settings:
- On the remote control, press the
(Quick Settings) button.
- Select Settings → Remotes and accessories → BRAVIA Cam → Proximity Alert.
What is the sensing range of BRAVIA Cam?
What if the distance from the TV recognised by the camera sensing function seems inaccurate?
Auto adjust picture & sound
- Not all TV models support the Auto adjust picture & sound feature.
- If your BRAVIA TV supports this feature, settings such as Auto adjust with camera, Auto adjust picture & sound, and Auto adjust according to viewing position will be displayed in the Quick Settings or Picture settings.
(Quick settings) button.
- The next steps will depend on your TV menu options:
- Search for Auto adjust picture & sound or Auto adjust according to viewing position.
- Select Picture settings → Auto adjust with camera.
- Select Settings → Display & Sound → Picture → Auto adjust picture & sound.
- The Auto adjust Picture & Sound camera sensing features are available after a software update.
Where is the camera setting for Auto adjust picture & sound?
Is it possible to set how the Auto adjust picture & sound function recognises people?
Auto adjust picture & sound sometimes doesn't work
After using the Auto adjust picture & sound option, the set value doesn't return to the default.
Precautions when using Calman for BRAVIA and Auto adjust picture & sound at the same time
Can I adjust the soundbar audio by using Auto adjust picture & sound?
Gesture Control
If your BRAVIA TV supports the Gesture Control function, this feature will be displayed in the BRAVIA Cam settings:
- Select Settings → System → Gesture Control.
Are there more gestures than those shown in the tutorial?
Gestures may not be recognised in the following circumstances:
Gestures can be detected by unintentional action:
Proximity Alert
- If your BRAVIA TV supports the Proximity Alert function, this feature will be displayed in the BRAVIA Cam settings:
Information on BRAVIA Cam's Video Chat
There's sound but no image when I use the Video Chat application with BRAVIA Cam
LED
What is the white LED indicator on the BRAVIA Cam, and when does it light up?
The camera LED indicator is lit even though the shutter has closed
The camera image has white noise while shooting
The camera image has a flicker
Software update
BRAVIA Cam doesn't respond after removing and inserting it during a camera update
Others
The BRAVIA Cam attached to the top centre of the TV is getting warm
