Article ID : 00286227 / Last Modified : 10/02/2026Print
    How to use the Living Decor app to display your favourite images on your TV
    The Living Decor app can transform your TV into an interior accessory with sophisticated images and a variety of music themes, photos, and clock functions.
    Note: The Album by Google Photo feature ended on 28 March 2025 due to a Google software change. If you want to set Google Photos as your Google TV™ screensaver, refer to the following Google support page: Change the screensaver on Google TV.
    Choose a Living Decor theme to suit your mood
    The free Living Decor app has images and slideshows with various themes that you can pair with music. When you want to relax, take a break in a cafe atmosphere, or entertain guests, why not make your living room a comfortable space by playing your favourite images or slideshows on your BRAVIA TV?
    The available Living Decor themes are displayed with thumbnails (as shown below).
    Setting up the Living Decor app
    1. On the remote control, press the HOME / (HOME) button.
    2. Select Apps.
    3. Select Living Decor under Your apps.
      Note: After launching the Living Decor app, you can select a theme by pressing the Enter button on the remote control.
    Tip: Living Decor can be used as a clock to display the time, local weather, and temperature on the screen. It has a subtle design that doesn't compromise the ambience of the visuals.
    You can customise the presence and position of the clock and weather display to suit your preferences:
    1. With Living Decor selected, press the Enter button on the remote, then select the Settings icon on the screen.
    2. You can adjust the display content by going to Display → Item Display Settings.
