Supported media file formats vary depending on your model and the Media Player app you downloaded from the Google Play Store.
Select your TV model or model group:
BRAVIA 2 (S20), W8x5_W8x6, W8L, X64L_X70L_X74L_X75L, X77L_X78L, W8K, X74K_X75K, W8, X7, X74H_X75H series
BRAVIA 3 (S30), BRAVIA 2 II (S20M2)
BRAVIA 3 II (XR30M2)
Other Google TV™ and Android TV™ models
Additional information
- The Media Player app does not support Dolby content.
- For the file formats supported by the Media Player, Video, or Photo apps that came preinstalled on the TV, refer to your TV’s Help Guide or
- If the TV cannot play a listed format, update the TV software. For instructions, refer to the How to perform a software update.
