Article ID : 00256093 / Last Modified : 07/07/2026Print
    Using Text magnification on your BRAVIA TV
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article.
    The Text magnification function shows an enlarged version of the menu text that is in focus.
    The larger text will appear at the top or bottom of the screen in a dedicated window. If there is a lot of text that needs to be shown, it will be shown one line at a time. How long you have to read each line is called Duration and can be customized in the Settings menu.
    Notes:
    • When the Text magnification function is turned ON, editing of INPUT and Quick settings will not be available.
    • The Text magnification function is automatically added to the Quick Settings menu once enabled.
    Enabling Text magnification
    1. On the remote control, press the Quick Settings (spanner or gear) button and select Settings.
    2. The next steps will depend on your TV menu options:
      • Select Accessibility.
      • Select SystemAccessibility.
    3. Select Text magnification.
    4. Select Enable.
    Changing the color of the text
    4. Select Configuration.
    5. Select Color.
    6. Select your preferred combination of text and background color: White on black, Black on white, or Yellow on black.
    Changing the duration of the appearance of text
    5. Select Duration.
    6. Select your preferred duration from Very short to Very long.
