Please refer following settings:
IMPORTANT: This is a model-specific solution, view the Applicable Products and Categories for this article to verify that these specifications apply to your model.
- Enable the Built-in Wi-Fi setting on your TV.
- Using the TV remote control, press the HOME button.
- Select Settings.
- Select Network in the NETWORK & ACCESSORIES category.
- Select Advanced settings.
- Select Built-in Wi-Fi, and change to On.
- Turn on the Wi-Fi Direct setting of the TV.
- Select Settings.
- Select Wi-Fi Direct, and change to On.
- Display the TV's WPA key.
- Select Settings.
- Select Wi-Fi Direct.
- Select Wi-Fi Direct Settings.
- Select Show Network (SSID)/Password.
- The SSID and the WPA key will be displayed on the TV screen.
- On the Wi-Fi setting of the Wi-Fi Direct device, select the SSID of the TV and enter the WPA Key displayed on the TV screen as the password.
- If the connection is successful, the message Wi-Fi device is connected, is displayed on the TV screen.
NOTE: For more details refer to the manual supplied with your smartphone or tablet.
