Which Sony TVs do not support the A2DP Bluetooth profile?
This article applies only to the following Android TV models that don't support the A2DP Bluetooth profile.
- 2020 models: XH8005, XH8077, XH8096, XH8196 series
- 2019 models: XG8096, XG8196 series
- 2018 models: XF7596, XF8096, WF804, WF805 series
- 2017 models: XE8004, XE8005, XE8077, XE8088, XE8096, XE8099, XE8396 series
- 2016 models: All Android TV models
- 2015 models: All Android TV models
Note: For the Bravia TVs that support the A2DP profile, refer to the article Can I use Bluetooth audio devices with my Google TV™ or Android TV™?
Using a Bluetooth dongle or wireless transmitter
Since the TV models listed do not support the A2DP profile needed to send music to other devices, you need a workaround.
If you want to use Bluetooth headphones with these TVs, connect a wireless transmitter or Bluetooth dongle, such as Sony's Wireless Transmitter WLA-NS7 (sold separately), to the optical output terminal on the TV.
Notes:
- Below is an example image. A transmitter(A) is connected to the TV's optical or headphones output terminal. The headphones connect to the transmitter.
- If you try to pair the Bluetooth headphones to the TV directly, the Searching for accessories… screen appears and the connection cannot be established.
Connect your headphones via the wireless transmitter
For detailed information on the Sony wireless transmitters shown in this section, refer to the product pages.
- A Wireless Transmitter sold individually (WLA-NS7)
- A wireless transmitter that comes with the Wireless Neckband Speaker (SRS-NS7)
Note:
- For the Bluetooth headphones that have been tested with the Wireless transmitter (WLA-NS7), refer to the article What devices can I use to enjoy TV audio in 360 spatial sound?
- Watching a video on a non-BRAVIA XR TV while listening to its audio using the SRS-NS7/WLA-NS7 may cause unsynchronized video and audio.
How to set up
For details on connection with the transmitter and settings on the TV, refer to the following:
2. Configure the TV settingsTroubleshooting
If there is no or low sound, set Digital audio out volume to Max. For details, refer to the following:
How to set Digital audio out volume
