Article ID : 00401132 / Last Modified : 28/05/2026Print
Enable Text scaling on your Google TV
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article for details.
    Text scaling allows you to adjust the size of on-screen text on your Google TV™. By increasing the text size from 85% to 130%, you can make the program guide, settings screen, and other on-screen text larger. This may improve text readability.
    To turn on the Text scaling:
    1. On the remote control, press the Quick Settings (spanner or gear) button, then select Settings.
    2. Select Accessibility.
    3. Select Text scaling.
    4. Select the text size.
