Article ID : 00260903 / Last Modified : 02/06/2025Print
    Reduce image retention or non-uniformity on your OLED TV screen
    After using the TV, use the TV remote control Power button to turn the TV off and leave it off for one night. It is recommended that you perform this operation every time you use the TV.
    You can also reduce image retention by performing the following Panel Calibration as if the TV was turned off overnight:
    1. On the remote control, press the Quick Settings (spanner or gear) button.
    2. Select Settings → System → Retail mode settings → Picture reset mode → On.
    3. Turn the TV off and then back on using the AC power.
    4. Before running the Panel calibration, a dialogue will appear on the screen. Start the Panel calibration from this dialogue.
      Notes:
      • If Picture reset mode is On and you disconnect and reconnect the power cord and then turn on the TV, it will go into standby for approximately 10 minutes to perform the Panel calibration. After the Panel calibration is complete, the power will restart and display the TV screen. You can now set Picture reset mode back to Off.
      • By setting Picture reset mode to On, the settings for picture and sound will be reset. Record your current settings before performing the Panel calibration. You can restore your original settings after returning Picture reset mode to Off.
