Note: Depending on the TV model, Google Assistant may be referred to as Voice Assistant.
Content
- What languages does Google Assistant support?
- How can I change the language on my TV?
- Can I use Google Assistant if I don't sign-in to my Google account?
- How can I see the command list?
- When can I use Google Assistant in the different language?
- How to search for broadcast-related content using Google Assistant
For How to use Google Assistant, see the following: How to use Google Assistant
Refer to the following article: Supported countries/regions/languages and how to use Google Assistant
Follow these steps to change the language on your TV:
- Open the
Settings screen. How to access the Settings
- The next steps will depend on your TV menu options:
- Select System → Language → desired language.
- Select Device Preference → Language → desired language.
- Select Language → desired language.
It depends on your TV.
- For Google TV™: No. It is required that you sign-in to a Google account in order to use Google Assistant.
- For Android TV™: Yes, you can use Google Assistant, but with limited functions only.
For a list of commands, refer to the Google Assistant Help article.
When can I use Google Assistant in a different language?
We will announce it when that ability is ready.
Google Assistant can respond to your search request, depending on what you are doing with the TV, such as watching TV programs or recorded content.
For instance, if you say a search keyword when watching TV, Google Assistant will provide a list of TV programs that matches the keyword and are being broadcasted now as well as those in the future. If you say a search keyword when the recorded list is displayed, Google Assistant will show recorded content that matches the keyword.
