Article ID : 00167918 / Last Modified : 16/01/2026Print
    TV leans back a little on the table-top stand
    Your BRAVIA TV is designed to be slanted slightly backwards in consideration of setting on a low board.
    image of viewing angle vs television
    • If the TV is set at a low position, your eyes will lower a bit when you sit on a sofa. According to ergonomics, your eyes while sitting are 15 degrees lower than when you are in a usual relaxed state. You will be able to enjoy watching TV programs more comfortably by turning the TV screen a little upward.
    • If the TV is unstable, the screws that secure the stand to the TV might not be firmly tightened. By tightening all the screws again, the TV will be stable on the TV stand.
