These dimensions are approximate values. Measurements are provided in millimetres (mm).
Some models are not available depending on your country or region.
For the dimensions when using the Sony Wall-Mount Bracket, refer to the Wall-Mount Bracket Installation Information on the product support website.
Using a stand
(mm)
| Model (XBR-, KD-, KE-) | A | B | C | D | E | F | G |
| 85X80xH, 85X80xxH, 85XH80xx | 1899 | 1089 | 1532 | 1174 | 71 | 442 | 180 |
| 75X80xH, 75X80xxH, 75XH80xx | 1686 | 968 | 1324 | 1042 | 85 | 414 | 160 |
| 65X80xH, 65X80xxH, 65XH80xx | 1462 | 840 | 1126 | 905 | 82 | 340 | 135 |
| 55X80xH, 55X80xxH, 55XH80xx | 1243 | 719 | 979 | 782 | 80 | 340 | 135 |
| 49X80xH, 49X80xxH, 49XH80xx | 1101 | 646 | 554 | 704 | 63 | 286 | 113 |
| 43X80xH, 43X80xxH, 43XH80xx | 970 | 571 | 544 | 630 | 63 | 286 | 113 |
Mounting on a wall
For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
Make sure you use the specified wall-mount bracket. For details, refer to the manual for the TV.
(mm)
| 85X80xH, 85X80xxH, 85XH80xx | 1899 | 1089 | 400 | 400 | 750 | 548 |
| 75X80xH, 75X80xxH, 75XH80xx | 1686 | 969 | 300 | 300 | 693 | 525 |
| 65X80xH, 65X80xxH, 65XH80xx | 1462 | 840 | 300 | 300 | 581 | 420 |
| 55X80xH, 55X80xxH, 55XH80xx | 1243 | 718 | 300 | 300 | 472 | 275 |
| 49X80xH, 49X80xxH, 49XH80xx | 1101 | 645 | 200 | 200 | 451 | 381 |
| 43X80xH, 43X80xxH, 43XH80xx | 970 | 570 | 100 | 200 | 435 | 307 |
G: M6 holes for wall mount bracket
*Refer to the instruction manual for screw length information.
