Article ID : 00263723 / Last Modified : 29/09/2026Print
    Which BRAVIA TVs support HDMI 2.1 features?
    Find your BRAVIA TV model in the tables below to check which of the listed HDMI 2.1 features it supports. For a general explanation, see What is HDMI 2.1? Features and benefits explained.
    What the features mean:
    • 8K60 and 4K120 mean 8K video at up to 60 frames per second and 4K video at up to 120 frames per second.
    • eARC sends audio to a compatible soundbar or receiver.
    • VRR (Variable Refresh Rate) helps make gameplay smoother.
    • ALLM (Auto Low Latency Mode) automatically switches to a low-latency picture mode when a compatible device requests it.
    Before connecting a device:
    • A ✓ means that the TV supports the feature; it does not mean that the feature works on every HDMI input. Check your exact model’s specifications for supported HDMI inputs.
    • For 4K120 or VRR, you may also need to change the HDMI signal format and use a compatible device and cable. See What is VRR and how do I enable it on my TV? for more information.
    Table key: ✓ = Supported; – = Not supported. “*1” means the feature requires a software update.
    2026 BRAVIA TV models
    2026 BRAVIA TV HDMI 2.1 feature support
    Model8K604K120eARCVRRALLM
    BRAVIA 2 II (S20M2 series)––✓–✓
    BRAVIA 3 II (XR30M2 series)–✓✓✓✓
    BRAVIA 6 (A60 series)–✓✓✓✓
    BRAVIA 7 II (XR70M2 series)–✓✓✓✓
    BRAVIA 9 II (XR90M2 series)–✓✓✓✓
    2025 BRAVIA TV models
    2025 BRAVIA TV HDMI 2.1 feature support
    BRAVIA 3 (S30 series)––✓–✓
    BRAVIA 8 II (XR80M2 series)–✓✓✓✓
    BRAVIA 5 (XR50 series)–✓✓✓✓
    2024 BRAVIA TV models
    2024 BRAVIA TV HDMI 2.1 feature support
    BRAVIA 9 (XR90 series)–✓✓✓✓
    BRAVIA 8 (XR80 series)–✓✓✓✓
    BRAVIA 7 (XR70 series)–✓✓✓✓
    2023 BRAVIA TV models
    2023 BRAVIA TV HDMI 2.1 feature support
    X80L / X81L series––✓–✓
    X82L series––✓–✓
    X75WL series––✓–✓
    A95L series–✓✓✓✓
    A80L / A83L / A84L series–✓✓✓✓
    A75L series–✓✓✓✓
    X95L series–✓✓✓✓
    X93L series–✓✓✓✓
    X90L / X91L series–✓✓✓✓
    X85L series–✓✓✓✓
    XRM-xxA95L series–✓✓✓✓
    XRM-xxA80L series–✓✓✓✓
    XRM-xxX95L series–✓✓✓✓
    XRM-xxX90L series–✓✓✓✓
    KM-xxX85L series–✓✓✓✓
    2022 BRAVIA TV models
    2022 BRAVIA TV HDMI 2.1 feature support
    Z9K series✓✓✓✓✓
    XRM-Z9K series✓✓✓✓✓
    X80K / X81K / X82K series (43-75)––✓–✓
    KM-X80K series––✓–✓
    Other 2022 models–✓✓✓✓
    2021 BRAVIA TV models
    2021 BRAVIA TV HDMI 2.1 feature support
    Z9J series✓✓✓✓ *1✓
    XRM-Z9J series✓✓✓✓ *1✓
    X91J (85) series–✓✓✓ *1✓ *1
    X85J / X86J / X89J series–✓✓✓ *1✓
    KM-X85J series–✓✓✓ *1✓
    X80J / X81J / X82J series––✓–✓ *1
    KM-X80J series––✓–✓ *1
    X79J series–––––
    Other 2021 models–✓✓✓ *1✓
    *1 Software update required: Update the TV to the latest software version to use the marked features. See How to perform a software update.
    2020 BRAVIA TV models
    2020 BRAVIA TV HDMI 2.1 feature support
    Z8H / ZH8 series✓✓✓––
    XH90 / X90H / X91H / XH92 series–✓ *1✓ *1✓ *1✓ *1
    KM-X9000H series–✓ *1✓ *1✓ *1✓ *1
    A8 / A8H series––✓––
    A9 / A9S series––✓––
    XH85 / X85H / XH91 series––✓––
    XH95 / X95H series––✓––
    Other 2020 models–––––
