Article ID : 00303912 / Last Modified : 18/12/2023Print
    My Android TV can't connect to a Wi-Fi network after a software update (PKG6.6053)
    Are you experiencing Wi-Fi connection issues with your Android TV? For instance, do you see an error message displayed, or is your TV unable to make a connection even though it can find the available access points? If yes, this may be caused by a software update to version PKG6.6053.
    First, confirm whether your TV is on the list of applicable models:
    If your TV is on the list, refer to the following troubleshooting steps:
    The TV can’t connect to Wi-Fi for the first 15 minutes after the update
    Wait 15 minutes and see if the TV can connect to the Wi-Fi network without problems.
    • If yes, the issue will not happen again.
    • If no, please continue reading.
    The TV is having difficulties connecting to networks using recent Wi-Fi standards/features not supported by the TV
    1. Try to connect the TV to another network (i.e., a mobile hotspot).
    2. Check your Wi-Fi router to see if the Fast Roaming setting is enabled.
      • If yes, disable it and check if the problem to connect to the Wi-Fi network still exists.
        • Note: The Fast Roaming setting may have a different name depending on the brand of equipment used.
    For TP-Link customers
    If you’re using equipment from TP-Link such as the Deco M4 and/or Deco X20, you can disable the Fast Roaming setting in the Deco app:
    If the issue is still not resolved, use a wired network as a temporary solution and wait for a future software update.
