Article ID : 00269639 / Last Modified : 20/01/2026Print
    How to enjoy 3D surround with the Neckband Speaker or Sony brand headphones
    IMPORTANT: This article applies only to specific products and/or operating systems. Check Applicable Products and Categories for details. It may not be sold depending on your region or country.
    By connecting the transmitter supplied to the Wireless Neckband Speaker (SRS-NS7), or the optional wireless transmitter (WLA-NS7), to a BRAVIA XR series and making certain settings, you can enjoy the realistic sound of 3D surround with the Neckband Speaker, or Sony headphones.
    In addition, you can use your ear-shape data with a compatible app to help you achieve more immersive and optimised 3D surround effects.
    You can check a list of compatible Sony brand headphones here.
    TV, transmitter and a Wireless Neckband Speaker (SRS-NS7) connection image
    Notes:
    • If you are using BRAVIA Theater U, you will need the WLA-NS7 (not supplied) wireless transmitter.
    • To enjoy this feature, please update the TV software to the latest version.
    1. How to connect the TV and transmitter
    Connect the transmitter to the TV. For details, refer to the instruction manual supplied with the Wireless Neckband Speaker (SRS-NS7 or Bravia Theatre U), or the wireless transmitter (WLA-NS7). Manuals are also posted on the support website.
    The optical digital output terminal and USB terminal are on the back or side of the TV. Check the Setup Guide that supplied with the TV for the location of each terminal.
    Image of connect 2 cables
    2. How to set up 3D surround on the TV
    Click the options below to expand them.
    You can also wait with setting up the 3D surround settings. If you wait, make sure the TV and transmitter are connected before setting up the 3D surround:
    3. 3D surround volume and stop/restart
    Once the initial setup is complete, you can enjoy 3D surround using the Neckband Speaker or headphones.
    • If you use 3D surround, there will not be any sound output from the TV. The volume control button on the TV remote control will be disabled, so use the Neckband Speaker or Headphones to adjust the volume.
      Depending on your headphone model, you may have to adjust the volume using the Sony | Headphones Connect app. For details, please check the headphones instruction manual.
    • On the other hand, if you connect the Neckband Speaker or headphones directly to the TV via Bluetooth, you will not be able to enjoy 3D surround.
    How to disable 3D surround
    Turn off the Neckband Speaker or headphones, or turn off 3D surround from the Quick Settings (spanner or gear), 3D surround ends and the TV outputs sound.
    Note: If there's no sound from the TV speakers after turning off the Neckband speaker or headphones, also turn off 3D surround.
    How to enable 3D surround
    To use the Neckband Speaker or headphones again, on the TV remote control press the Quick Settings (spanner or gear) button and turn on 3D surround.
    Note: If the TV already has the 3D surround turned on, you can enjoy the 3D surround by turning on the Neckband speaker or headphones with the transmitter connected to the TV. If you can't start 3D surround after turning on the Neckband speaker or headphones, turn on 3D surround.
