IMPORTANT: This article only applies to specific products, countries, and/or operating systems. For the applicable products, please check the Applicable Products and Categories section of this article. For the applicable countries/regions and operating systems, please refer to this article: Countries and regions where Sony's TV supports Amazon Alexa devices.
Index
Interesting articles
What is Amazon Alexa?
Alexa is a cloud-based voice service from Amazon. It utilises voice-driven Alexa Cloud Service capabilities called Alexa Skills. These skills allow you to control certain features of your Amazon Echo and Amazon Echo Dot devices using the Amazon Alexa app. With this feature, you can use your voice to turn your TV on or off, change channels, control the volume, and more.
Supported TV models
If your TV supports Amazon Alexa, you should see one of the following apps available in the Apps list.
- TV Control with Smart Speakers
- TV Control Setup with Amazon Alexa
Note: You can't install these apps yourself.
How to use Amazon Alexa
Which Sony Alexa Skill is compatible with my TV?
What do I need to control my TV with Amazon Alexa?
What can I control on my TV with Amazon Alexa?
How to set up Amazon Alexa
Can I change channels with Alexa on my cable or satellite box?
What are Scenes?
Can I control multiple TVs with the same Alexa account?
What is the best name to choose for my TV when using Alexa?
Why do I need to link my TV to the Sony video skill?
Can I link two video skills to one Echo device?
Why do I have to pair my remote control to change channels on my cable or satellite box when using Alexa?
Can I use an Alexa Show device to control my TV?
Troubleshooting
The TV can't be turned on using Amazon Alexa-enabled devices
My TV doesn't respond to Amazon Alexa commands
Device discovery fails on the "TV Control with Smart Speakers" or "TV Control Setup with Amazon Alexa" app
There are multiple TV names for the same TV in the Amazon Alexa app
Attributions
* Amazon, Echo, Alexa, and all related logos are trademarks of Amazon.com, Inc. or its affiliates.
