Article ID : 00162475 / Last Modified : 01/05/2020Print
    How to register the One-touch Remote Control to the TV
    1. Using the supplied TV remote control, press the HOME button.
    2. Select Settings
    3. Select Preferences
    4. Select One-touch Remote Control Setup
    5. Select Register
    6. Using the One-touch Remote Control, press the COLOR KEY and the HOME button at the same time.
    Once the remote has been registered to the TV, you will be able to pair it with a compatible smartphone or tablet device for one-touch mirroring.
