Article ID : 00176478 / Last Modified : 10/02/2026Print
    Troubleshoot Bluetooth device connection issues with Android TVs released in 2017 and after
    The steps to troubleshoot Bluetooth® connection issues that may occur between your audio device and Android TV™ device will depend on the symptom. Follow the troubleshooting steps provided for the symptom you are experiencing.
    A separate article is available if you want to check if you can use your Bluetooth headphones, speakers, or soundbars with your TV.
