Article ID : 00409925 / Last Modified : 27/08/2026Print
    How to adjust the date and time on the TV
    IMPORTANT: This article only applies to specific products. Please check the Applicable Products of this article.
    The date and time are usually set automatically because the TV retrieves the date and time information from the broadcast signals or the network. If there are no broadcast signals or network connections available, you may need to set the date and time manually.
     Note: In the Netherlands, TV models get date & time from broadcast only.
    Set the date and time automatically
    With the TV receiving a broadcast signal or connecting to the network, follow these steps to check the setting:
    1. On the remote control, press the HOME button.
    2. When the Home screen is displayed, press the Dashboard (gear) button on the remote control.
    3. Select All Settings.
    4. Select System.
    5. Select Date & time.
    6. Select Automatic date & time.
    7. Select Use network-provided time.
    Set the date and time manually
    4. Select System.
    6. Select Automatic date & time and set to Off.
    7. To set the date and time manually, select Set date and Set time.
