Article ID : 00239720 / Last Modified : 04/12/2020
Sound Bar - Optical digital audio
    • The terminal locations will differ depending on your Sound Bar system. Refer to the operating instructions for more information. Manuals, Specifications and Warranty information for your Sony product is available online.
    • Depending on the model, it may be necessary to switch the Sound Bar settings to TV after connecting. For details on how to operate your Sound Bar system, refer to its operating instructions.
    • If the Sound Bar comes with a Subwoofer, avoid leaving items on top of the Subwoofer. Since the Subwoofer produce vibrations, any items placed on top of it may fall.
    Connection Diagram of Sound Bar (Optical digital audio)
    1. Sound Bar (rear)
    2. OPTICAL DIGITAL AUDIO IN
    3. OPTICAL DIGITAL AUDIO OUT
    4. Optical digital audio cable
    NOTE: If you will use the BRAVIA Sync feature or send video signals from a connected device to the TV through the Sound Bar, connect them with both the optical digital cable and HDMI cable.
    Connection Diagram of Sound Bar (HDMI without ARC)
    1. Sound Bar (rear)
    2. HDMI TV OUT (ARC)
    3. OPTICAL DIGITAL AUDIO IN
    4. HDMI IN
    5. OPTICAL DIGITAL AUDIO OUT
    6. HDMI cable
    7. Optical digital audio cable
