Article ID : 00202534 / Last Modified : 19/01/2026Print
    Operating a set-top box (cable/satellite box) with the TV remote control
    You can operate a set-top box (cable/satellite box) with your TV remote control by connecting an IR Blaster to your TV and completing the IR Blaster setup.
    By pressing the STB MENU button (or EXT.BOX MENU button), the cable/satellite box menu appears on the TV screen.
    You can also operate your cable/satellite box using the GUIDE button and the TITLE LIST button on your TV remote control.
