Article ID : 00202418 / Last Modified : 10/02/2026Print
    Voice Recognition Features
    Voice search and Google Assistant
    Sony's Android TV has a voice recognition feature. This feature is called “voice search” and allows you to input commands into the TV using your voice. If your TV has the Google Assistant built-in, you can ask your Google Assistant for help.
    Whether the TV supports the Google Assistant varies depending on your region or language. For details, refer please here.
    For how to use the Voice search function, please refer here.
    Hands-free voice search Experience (only TVs with a built-in MIC)
    If the TV has “Ok Google” detection setting, you can use voice search or operate the TV hands-free.
    If the TV supports Google Assistant, you can ask Google Assistant hands-free.
    Whether the TV supports “Ok Google” detection setting varies depending on your region or language. For details, please refer here.
    NOTE: The Google Assistant or voice search requires an Internet connection.
    *Google, Android TV and related marks and logos are trademarks of Google LLC.
