IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article for details.
Text scaling allows you to adjust the size of on-screen text on your Google TV™. By increasing the text size from 85% to 130%, you can make the program guide, settings screen, and other on-screen text larger. This may improve text readability.
To turn on the Text scaling:
- On the remote control, press the Quick Settings (
or
) button, then select
Settings.
- Select Accessibility.
- Select Text scaling.
- Select the text size.
