Article ID : 00345868 / Last Modified : 27/05/2026Print
    Tactile dots near the connection terminals
    Tactile dots are included near the terminals to help you connect to your soundbar without confusion.
    To connect the soundbar to your TV, you can identify and use the following tactile dots:
    • Three round tactile dots located near the eARC/ARC terminal.
    • Two round tactile dots located near the S-CENTER SPEAKER IN terminal.
    Image of the connectors on the back panel of a television.
    Note: Tactile dots may not be available depending on the model.
