NOTE: Not all TVs are supplied with colour buttons. To see if your TV has the colour buttons, check the specifications or the instructions manual supplied with the product.
When entering the security key for your home network or using the Internet browser the coloured buttons will allow you to perform the following actions:
IMPORTANT: The colours of the buttons may differ depending on the models or regions.
| A/a | This button allows you to select between lowercase to uppercase letters. |
| Delete / Backspace | This button allows you can delete characters, numbers or symbols. |
| Input Mode | This button allows you to change the input language. |
| ABC | This button allows you to select between letters, numbers or symbols. |
