Article ID : 00081197 / Last Modified : 12/07/2018Print
    How to connect your computer, tablet or phone with your non- Android TV via Wi-Fi Direct
    BEFORE GETTING STARTED
    • Some models require the UWABR100 USB Wireless LAN Adapter to be connected to the TV and a software update to enable Wi-Fi Direct. For further details, please refer to the operating instructions supplied with your product.
    • Make sure the TV has the latest system software (firmware) update installed.
    • Not all BRAVIA TVs are Wi-Fi enabled. In case of doubt, please check the User Manual or Specifications on the Support site.
    TABLE OF CONTENTS
    1. Preparation
    2. Computer
    3. Tablet (Android)
    4. Phone
    1. Preparation
    1-1. Find Wi-Fi Direct mode on your BRAVIA
    Depending on your TV menu type:
    • Menu TV-1: Select Wi-Fi Direct Mode by pressing "Home" (MENU) on your remote control > [Applications] > [Wi-Fi Direct Mode].
    Wifi_Direct_Fig1
    • Menu TV-2: Under [Settings] [Network], confirm that [Build-in Wi-Fi] and [Wi-Fi Direct] are [On]. Then select Wi-Fi Direct Settings.
    Wifi_Direct_Fig1-a
    • Menu TV-3: Under [System Settings] [Wi-Fi Setup], confirm that [Build-in Wi-Fi] and [Wi-Fi Direct] are [On]. Then select Wi-Fi Direct Settings.
    Wifi_Direct_Fig1-b
    1-2. Launch Wi-Fi Direct mode
    Press“Options” on your remote control Select [Manual]
    Wifi_Direct_Fig2 Wifi_Direct_Fig2-a
    Select [Other Methods] You will get the SSID and the WPA Key to setup your device Wi-Fi
    Wifi_Direct_Fig2-b Wifi_Direct_Fig2-c
    NOTE: The WPS setting is not available on all Wi-Fi Direct capable devices. Refer to the manual supplied with the cell phone, computer or other Wi-Fi Direct device for information regarding the WPS setting.
    2. Computer
    2-1. Connecting
    Click the Network Icon and enter the network setting.
    On the system tray click "Network Icon" and enter the network setting
    From network settings select the SSID supplied by your BRAVIA TV
    Win7-1 Win7-1-a
    Input the WPA Key supplied by your BRAVIA TV and press “OK”
    Win7-1-b
    Your PC is now connected with your BRAVIA TV.
    2-2. Sending content & playback
    Using Windows Media Player
    Launch "Windows Media Player" (Start menu -> Search -> Windows Media Player) or the icon on the “Quick Launch Toolbar” Under the [Stream] tab check that the [Automatically allow devices to play my media…] is enabled.
    win7-8 arrow-right win7-8-a
    arrow_down
    Select some content (pictures, movies or music). Then click right button and select [Play to] -> [BRAVIA]
    Press the [Play] button win7-8-c
    win7-8-b arrow_left
    arrow_down
    Watch it on your BRAVIA TV
    lcd-tv
    Using Windows Explorer
    Single file
    Launch "Windows Explorer" (Start menu -> Search-> Windows Explorer) or the icon on the “Quick Launch Toolbar tip_arrow_right
    TIP- You can go directly to Windows Explorer by pressing at the same time the [Windows] Key and the [E] key.
    tip
    win7-13 Open folder which contains the content (pictures, movies or music), select the file and right-click on the file and select [Play to]-> [BRAVIA]
    arrow_right win7-9
    win7-8-b arrow_left
    arrow_right lcd-tv
    Multiple Files (Slideshow)
    Right click the folder which contains the contents (pictures, movies or music) and select [Play to] -> [Bravia]
    win7-10
    Press the [Play] button, and start slideshow with all included contents
    arrow_right win7-12
    lcd-tv arrow_left
    3. Tablet (Android)
    3-1. Connecting
    From Menu select “Settings” From Wi-Fi select the SSID supplied by your BRAVIA TV
    tablet-1 arrow_right tablet-2
    arrow_down
    Input the WPA Key supplied by your BRAVIA TV and press “Connect”
    tablet-3
    Your Android Tabletis now connected with your BRAVIA TV
    3-2. Sharing content
    Choose the application and the file you want to share on your BRAVIA TV. Keep in mind that only pictures and movies or music can be shared.
    On the top of the screen you will find the share icon tablet-7 Select the BRAVIA TV that you want to use for share
    tablet-4 tablet-5
    Wait until the transfer is done Watch it on your BRAVIA TV
    tablet-6 lcd-tv2
    4. Phone
    As soon as a connection has been established, media can be shared between a Wi-Fi Direct device and a Wi-Fi Direct compatible Sony TV using iMediaShare software or DiXiM software or other applications. For information on how to get specific Wi-Fi Direct applications on your cell phone, please refer to the manufacturer's website.
    4-1. Android phone
    Connecting
    On you mobile settings select Wi-Fi From Wi-Fi select the SSID supplied by your BRAVIA TV Input the WPA Key supplied by your BRAVIA TV and press“Connect”
    phone-1 phone-2 phone-3
    Your Android Phone is now connected with your BRAVIA TV.
    Sharing content
    Chose an application and the file you want to share with it on your BRAVIA TV. Keep in mind that only pictures and movies or music can be shared.
    On the top of the screen you will find the share icon phone-4 Press drop down list to select the player device Select the BRAVIA TV that you want to use for share
    phone-5 phone-6 phone-7
    Press“Play” Wait until the transfer is done Watch it on your BRAVIA TV
    phone-8 phone-9 lcd-tv3
    4-2. iPhone
    Find out how to establish a Wi-Fi Direct connection with an iPhone.
