To output TV sound from the audio devices with Optical Digital Audio Out jacks or HDMI ARC jacks, set ClearAudio+ and Hi-Res Up-Scaling (DSEE HX) to Off with the following steps:
NOTE:
- X9350D/X94xxC/X93xxC series supports High-Resolution Audio but cannot output High-Resolution Audio from the Optical Digital Audio Out jacks or HDMI ARC jacks.
- High-Resolution sound output will only work with the built-in speaker of Sony's Android TV.
- Set ClearAudio+ to Off
- Press the HOME button on the remote.
- Select Settings.
- Select Sound in the TV category.
- Select Sound.
- Select ClearAudio+.
- Select Off.
- Set Hi-Res Up-Scaling (DSEE HX) to Off
- Select Settings.
- Select Sound.
- Select Hi-Res Up-Scaling (DSEE HX).
- Select Off.
