Generally, due to the characteristics of the materials used for organic EL displays to achieve high-definition imaging, the display is susceptible to screen image retention.
Panel calibration is a function that optimises the screen and reduces image retention or enhances the image in dark scenes.
Note: Panel calibration is performed automatically a few hours after the power is turned off with a remote control.
