Article ID : 00411704 / Last Modified : 14/09/2026Print
    Why do I receive another software update notification after updating my TV?
    Depending on the software version installed on your TV, you may need to complete more than one software update. After one update is complete, the TV may display another software update notification.
    This behavior is normal and does not indicate an issue with the TV.
    Note: If you update the TV software using a USB flash drive, you may also need to install multiple software updates before the update process is complete.
