Article ID : 00129896 / Last Modified : 16/01/2026Print
    My 3D photos and movies cannot be played from my USB memory stick or the Home network
    • 3D photos
      The TV does not support 3D photo content from the Home network or a USB memory stick.
    • 3D movies
      Content that supports 3D auto-play will be played automatically in 3D. If it does not play in 3D, choose 3D(Side-by-Side) or 3D(Over-Under) from 3D settings as follows.
      1. Press the Action Menu button on the remote.
      2. Select 3D in the Display & Sound category.
      3. Select 3D display.
      4. Choose 3D(side-by-Side) or 3D(Over-Under).
      NOTE: If the content is not played in 3D by the steps above, please update the TV software to the latest version, and try again. For how to update, refer to: How to perform a software update.
