Article ID : 00283843 / Last Modified : 10/02/2026Print
    What is Voice Zoom and how do I use it?
    How to raise and lower only the volume of the voice.
    Voice Zoom is a feature that enables you to customise your auditory experience by adjusting the volume of voices and ambient audio to your preference.
    How is Voice Zoom useful?
    Voice Zoom works with all content, but we've found it especially useful when listening to commentators during sporting events.
    • Increase voice levels: In the case of a football match, increasing the voice level emphasises the commentator's voice while lowering ambient audio (background sound).
    • Lower voice levels: Lowering the commentary (voice) volume emphasises ambient audio, allowing you to immerse yourself in the sounds of the stadium.
    How to activate Voice Zoom
      The steps to use Voice Zoom vary depending on your TV.
      Note: Voice Zoom is only available on certain TV models.
      1. Open the Settings screen.
      2. The next steps will depend on your TV menu options:
        • Select Display & Sound → Picture & Sound → Sound (TV speakers) → Voice Zoom.
        • Select Display & Sound → Sound → Sound customization → Voice Zoom.
        • Select Sound → Sound adjustment or Sound → Voice Zoom.
      3. On the remote control, press the ← / → (right/left) button to adjust the sound to your desired level.
