Article ID : 00143757 / Last Modified : 16/01/2026Print
    How to use the Twin Picture function on Sony's Android TV?
    To display two pictures, follow the steps below:
    STEP 1: Select the HDMI input that the device is connected to.
    1. Press the HOME button on the remote.
    2. Select Inputs.
    3. Select HDMI 1-4.
    STEP 2: Select Twin Picture from the ACTION MENU.
    1. Press the ACTION MENU button on the remote.
    2. Select Twin Picture.
    STEP 3: To end Twin Picture mode, select Single Picture from the ACTION MENU.
    NOTES:
    • The TV cannot enter Twin Picture mode unless an HDMI input is selected
    • The only signals that can be displayed in Twin Picture mode are Digital 2K and analogue signals
    • The Twin Picture display function is available via a software update . Update to the latest software, and then check whether it is displayed in the menu.
