Article ID : 00285178 / Last Modified : 06/11/2024Print
    How to reset or initialize the Wireless Headphones (WF-SP900)
    Resetting the headphones
    If the headphones operations become unstable or freezes, try the following steps to reset the Headphones.
    Note: Resetting will not delete any data or pairing information.
    1. Hold down both buttons for 30 seconds until the player restarts.
      button location
    2. After the player restarts, the led will flash green twice.
      green lit
    Resetting the charging case
    If the problem persists even after you reset the player, or charging does not start, or if the charging lamp does not light up, try resetting the charging case.
    1. Press the RESTART button with a pen or a paper clip to restart the charging case.
      reset button location
    Initializing / Reformatting the headphones to restore factory settings
    Notes:
    • The configurations of various settings are reset to the factory preset values.
    • Bluetooth pairing information is deleted.
    • Data in the memory of the player is deleted (music data, pre-installed data, and so on).
    Before you perform this operation, save a backup copy of important data.
    1. Pause playback.
    2. Make sure that the Bluetooth function is off.
    3. Hold down the button for 15 seconds. The led will flash slowly.
      button and yellow led location
    4. Release the button. The led will light up in red.
      red led location
    5. Press the button twice quickly within 30 seconds after the led lights up. The color of the led will change.
      If you do not press the button quickly twice within 30 seconds, reformatting will be canceled.
      led change from red to green
    6. Press the button while the led is lit up.
      The led will flash quickly and reformatting will start. When reformatting is complete, the led and the player will turn off.
      Green led lit
