If you are unable to project images in HDMI mode, please check the following items:
- If the message “No Wireless unit found” is displayed on the LSPX-P1 projection screen or the dedicated app:
- Make sure that the Wireless unit is correctly plugged in
- The distance between the Wireless unit and LSPX-P1 may be too long. Bring them closer to each other
- If the message “No input from HDMI.” is displayed:
- Make sure that an HDMI cable is correctly connected to the Wireless unit’s HDMI IN connector
- Make sure that the HDMI output device connected to the Wireless unit is turned on and set correctly to output HDMI
- When LSPX-P1 projects nothing:
- Make sure that the image output from the HDMI output device is not a black screen image.
On the dedicated app for mobile devices, select [Poster] once, then select [HDMI] again. - Restart LSPX-P1 and the Wireless unit (press and hold the power button to restart LSPX-P1)
