NOTE: Not all TVs are supplied with a USB input that supports a USB HDD. To see if your TV supports the use of a USB HDD, check the specifications or the instructions manual supplied with the product.
The TV is designed to supply USB2 standard power of 5 volts at 500mA (2.5 W).
If the external USB HDD exceeds 500mA (2.5 W), an external power supply must be used.
