Article ID : 00137224 / Last Modified : 16/01/2026Print
I can hear sound from my home theater, but not from the TV itself.
    If you want to hear sound from the TV while the TV is connected to a home theater, the speaker output setting must be changed to TV Speakers.
    NOTE: Sound cannot be output by the home theater and the TV simultaneously.
    2. Select Settings.
    3. Select System Settings.
    4. Select Set-up.
    5. Select AV Set-up.
    6. Select Speakers and set to TV Speakers.
